SPAN sessions
I'm running into a problem with the span session limits on the 6500's...right now we have two 6500's connected to each other with Layer 2 ether channel trunks, and both use monitor session 1 for the IDS. I use monitor session 2 for general trouble shooting when I need to...however now I have the need to add a 3rd and 4th session (for a net management tool and a filter) can I go about doing this with a 2 session limit?
Should I think about adding another switch (a 3750 or something like that) and just have a few RSPAN sessions on the 6500's sending traffic over to the 3750, and set up all the management tools as well as the IDS on there?
Kerem Gursu Wed, 02/18/2009 - 07:39
In a similar situation , I have replicated the span session with a network tap device. You only use one span session , but the tap device replicates this session within its ports.
There are many suppliers for this device , you can choose one of them.
Hope to help,
taali Wed, 02/18/2009 - 07:45
Virtual SPAN may be able to help here.
You can set up a single source SPAN with multiple destination trunk ports. As of 12.2(18)SXD, you can filter each destination trunk port by vlan. See the attached pdf for more information.
