E1 to WIC
Feb 17th, 2009
Hi ,
There is a Channelised E1 output which is from mux . as my controller port is faulty can i connect this outout of e1 ( RJ45) to 2mb modem ( RAD ASM)(using WIC in router) and get the link through ?
Actually i tried it and failed .. is there any suggestions ?
Overall Rating: 1 (1 ratings)
rahul0904 Wed, 02/18/2009 - 03:53
If I understand the setup correctly, you will require a RAD convertor modem as the output that you are getting is G.703 which needs to be converted to V.35
Paolo Bevilacqua Wed, 02/18/2009 - 03:56
The problem is that is not really clear what the OP wants to do.
Cisco routers have G.704/G.704 natively with the right cards and need no converters.
