Mother Board for mcs-7815l
Feb 17th, 2009
i have a mcs-785l-3.0 server for my ccm 4.1 and there is a problem on the Mother Board and some fans are not working properly so we checked thoroly then we noticed that some of capacitors are seems to be swallen so we need immediat help and a solution in case if we have to replace a Mother Board where we can buy.
thank
regards,
sampath.
Anonymous (not verified) Tue, 02/24/2009 - 18:27
Is this only one fan or multiple fans?
Is the rest of the board and components getting power (ex, hard drive turns, LED is on)?
Is there any amber/red LED's on the front panel or on the system board?
mihirasampath Tue, 02/24/2009 - 21:34
one fan(Processor fan)
no
no
But some capacitors (Condensers) are looking bad.
thanks
sampath.
david-lima Wed, 02/25/2009 - 06:10
mihirasampath Wed, 02/25/2009 - 23:03
Hi david
thank you for your response.I'll try with this.I think my machine is not under warranty now.Anyway i'll try to get tac support for this.
thanks again and link you gave me was very helpful to me.
sampath.
