VPN client got Disconnected
Feb 17th, 2009
hi all,
I am using Cisco ASA 5505 for establishing Remote access VPN
I am facing the following problems.
a. my branch office having two VPN clients.When a user connect for the first time he got connected.Then if the second user try to connect, he got connected, but the first user got disconnected.
b. After some time if the disconnected user try to connect,he got connected.
c.Both the users are using different usernames to authenticate
Head office internal network: 192.168.10.0/24
Branch office internal network:
192.168.10.0/24
Iam attaching my configuration
interface Vlan1
nameif inside
security-level 100
ip address 192.168.10.253 255.255.255.0
interface Vlan12
nameif outside
security-level 0
ip address 192.168.2.2 255.255.255.0
interface Ethernet0/0
switchport access vlan 12
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
passwd 2KFQnbNIdI.2KYOU encrypted
ftp mode passive
dns server-group DefaultDNS
domain-name default.domain.invalid
access-list inside_nat0_outbound extended permit ip any 150.1.1.0 255.255.255.0
pager lines 24
logging asdm informational
mtu inside 1500
mtu outside 1500
ip local pool remotepool 150.1.1.1-150.1.1.254 mask 255.255.255.0
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-522.bin
no asdm history enable
arp timeout 14400
global (outside) 1 192.168.2.10-192.168.2.100
nat (inside) 0 access-list inside_nat0_outbound
nat (inside) 1 0.0.0.0 0.0.0.0
route outside 0.0.0.0 0.0.0.0 192.168.2.1 1
group-policy yyyy internal
group-policy yyyy attributes
dns-server value 212.72.23.30 212.72.23.31
vpn-tunnel-protocol IPSec
username xxxx password eY/fQXw7Ure8Qrz7 encrypted privilege 0
username xxxx attributes
vpn-group-policy yyyy
http server enable
http 192.168.10.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto dynamic-map outside_dyn_map 20 set pfs
crypto dynamic-map outside_dyn_map 20 set transform-set ESP-3DES-SHA
crypto map outside_map 65535 ipsec-isakmp dynamic outside_dyn_map
crypto map outside_map interface outside
crypto isakmp enable outside
crypto isakmp policy 10
authentication pre-share
encryption 3des
hash sha
group 2
lifetime 86400
tunnel-group yyyy type ipsec-ra
tunnel-group yyyy general-attributes
address-pool remotepool
default-group-policy yyyy
tunnel-group yyyy ipsec-attributes
pre-shared-key *
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd auto_config outside
dhcpd address 192.168.10.254-192.168.10.254 inside
dhcpd enable inside
Expecting your valuable reply
mvsheik123 Fri, 02/20/2009 - 11:06
  • Gold, 750 points or more
Try enabling 'nat traversal' on ASA and give a shot.
crypto isakmp nat-traversal 20
hth
MS
