Call transfer problem on cme
Feb 17th, 2009
1 i have cisco 2811 with ios ver 12.3.Earlier i used ccm 4.1.Now I have configured my router to cme.But i cant transfer the out calls to numbers except the extentions even we have a E1 line too.
2 we have a problem when i transfer a call to a extention number too soon after type the extention number it will disapear from the display without any notice so we are not sure that it was tansfered or not. But when i use ccm 4.1 we can keep hold the original call and can talk with particular extention user before transfer the call.incase if that person is not available on that particular extention we can direct to another number
so can not i have the same facilities on cme which i use.
thanks/Regards
sampath
sampath
Paolo Bevilacqua Wed, 02/18/2009 - 00:01
Configure a transfer-pattern under telephony-service.
Recommend you upgrade CME/IOS, what you're using is really old.
