Upgrading DSP Channels for PRI lines
Answered Question
Feb 17th, 2009
We have two PRI and 4 BRI lines installed in our Cisco 7206. But we are using only 45 channels live in our PRI lines. Now when i tried to increase the time-slot from 15 channels to 30 channels for 1 PRI line, its giving error message. I like to know how many DSP channels/slots will be available in Cisco 7206 Router board. Please find below our router and dsp details.
Error Message:-
Cisco7206Router(config-controller)#pri-group timeslots 1-31
Current dsp resources can support 26 timeslots;need 2 extra dsps to support the requested configuration
Cisco Router 7206:-
cisco 7206VXR (NPE225) processor (revision A) with 114688K/16384K bytes of memory.
Processor board ID 23677191
R527x CPU at 262MHz, Implementation 40, Rev 10.0, 2048KB L2 Cache
6 slot VXR midplane, Version 2.0
DSP details:-
Dsp firmware version: 4.1.41
Maximum dsp count: 30
On board dsp count: 30
Jukebox available
Total dsp channels available 60
Total dsp channels allocated 45
Total dsp free channels 15
Querying dsp status......
Vidhu
Correct Answer by Paolo Bevilacqua about 7 years 11 months ago
No shutdown.
Overall Rating: 5 (2 ratings)
Paolo Bevilacqua Wed, 02/18/2009 - 01:34
Do you have dspfarm configured currently ?
Do you have other E1 ports doing voice in the same router ?
orbitbahrain Wed, 02/18/2009 - 01:40
This is the DSP FARM config,
dspint DSPfarm1/0
codec high ecan-extended
shut 0,6
We have totally 2 PRI lines,
controller E1 1/0
pri-group timeslots 1-16
controller E1 1/1
rEGARDS
VIDHU
Paolo Bevilacqua Wed, 02/18/2009 - 02:02
You have two dsps shutdown. Take them out of that condition and if they prove faulty RMA the PA.
orbitbahrain Wed, 02/18/2009 - 02:38
Thanks a lot for your gr8 support. Let me try out this command and get back to you if any issues.
Vidhu
