Cisco Catalyst 2950 C24 sopped at switch: pls help ........Urgently
Feb 18th, 2009
Dear All,
I have cisco 2950 C24 Switch which has some problem and and stopped at switch:
i had tried after rebooing but the same problem is there.
I have attached the capture fle for your refferencce .......
Pls help me to resolve it .....
Dipesh P
ccannon88567 Wed, 02/18/2009 - 02:26
Look's like your IOS has corrupted. I'm not sure if you can reseat the flash within the unit? If you can, that's worth a try - if not try loading a new one through xmodem.
Dipesh Patel Wed, 02/18/2009 - 03:37
Dear ccannon88567,
Thanks for Replying.
I habve already checked after formatting IOS and Loaded lattest IOS using Xmodem Method..
After Loading new IOS it works for half hour and again the same proble occured.....
Dipesh P
ccannon88567 Wed, 02/18/2009 - 04:11
Dipesh,
That's normally a bad sign. I would say that the switch is coming to the end of it's life due a hardware problem in that case.
As it's a 2950 I would recommend a new replacement rather than risk further downtime.
If you wanted to diagnose further then contact the Cisco TAC Centre and give them a copy of the sh tech command.
Maybe check with your supplier to see if they can replace through one of their policies also.
Carlton
glen.grant Wed, 02/18/2009 - 06:57
  • Purple, 4500 points or more
It doesn't look like there is any IOS in flash by your "dir flash" so it can't load it . You need to get a valid IOS in flash before it will boot.
Leo Laohoo Wed, 02/18/2009 - 19:27
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Hi Glen,
It's there.
4 -rwx 3722112 c2950-i6k2l2q4-mz.121-22.EA12.bin
Leo Laohoo Wed, 02/18/2009 - 14:40
  • Hall of Fame,
    2017 LAN, Wireless
Can you please try "boot flash:c2950-i6k2l2q4-mz.121-22.EA12.bin"?
From your switch error.txt, the filename is there but I have no idea why the switch is refusing to read it. It keeps on trying to find/read c2950-i6q4l2-mz.121-22.EA4.bin.
Dipesh Patel Wed, 02/18/2009 - 19:35
Dear all,
Thanks for reply.
I have checked after reloading new valid IOS which is working in another same model switch.
I have also used boot flash:c2950-i6k2l2q4-mz.121-22.EA12.bin.
Its worked 1st time and after half hour again stopped at switch: prompt......
Dipesh P.
Leo Laohoo Thu, 02/19/2009 - 14:37
  • Hall of Fame,
    2017 LAN, Wireless
Did the "boot flash:c2950-i6k2l2q4-mz.121-22.EA12.bin" work?
What do you mean "worked 1st time and after half hour again stopped at switch:"???
If it worked the first time, go to Global configuration mode and enter the following commands:
no boot system
boot system flash:c2950-i6k2l2q4-mz.121-22.EA12.bin
exit and save the config and try again.
Dipesh Patel Tue, 02/24/2009 - 03:25
Sorry for late reply ...
I had tried it also but not solved finally I have raised the RMA.
Thank you all for reply....
