BLF call pick up not working
Answered Question
Feb 18th, 2009
I have problems getting this to work.
On a 7965+7915 the BLF presence part works on the phone and on the expansion module but the call pick up doesn't.
It always states key not active on the phone and on the module
Thanks in advance
Correct Answer by Rob Huffman about 8 years 3 months ago
Hi Koenraad,
Did you have a look at these;
Cisco Unified CallManager Administration Configuration Tips
http://www.cisco.com/en/US/docs/voice_ip_comm/cucmbe/rel_notes/6_1_2/cucmbe-rel_note-612_2.html#wp308333
It almost sounds like the Pickup Groups have not been configured.
Rob
Overall Rating: 5 (1 ratings)
Rob Huffman Wed, 02/18/2009 - 05:59
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Koenraad,
Here is the related info :)
BLF Pickup Action
If a line is in the BLF alerting state, the local user can press the associated speed-dial button (BLF Pickup button) to pick up the call. The phone picks up the call on the next available line if the user does not first specify a line. If auto-pickup is enabled for the line, the call connects automatically; otherwise, the call rings on the local phone and the user must manually answer it.
Note Pressing the BLF Pickup button at a time when no BLF alerting indicators are present results in the phone speed dialing the associated directory number.
Unlike the existing BLF feature, BLF Pickup cannot be configured for a call log or directory listing;
***BLF Pickup works on a speed-dial line button only.
These BLF enhancements are supported on the following SCCP phones:
•Cisco Unified IP Phone 7975G
•Cisco Unified IP Phone 7971G-GE
•Cisco Unified IP Phone 7970G
•Cisco Unified IP Phone 7965G
•Cisco Unified IP Phone 7962G
•Cisco Unified IP Phone 7961G
•Cisco Unified IP Phone 7961G-GE
•Cisco Unified IP Phone 7945G
•Cisco Unified IP Phone 7942G
•Cisco Unified IP Phone 7941G
•Cisco Unified IP Phone 7941G-GE
•Cisco Unified IP Phone 7931G
http://www.cisco.com/en/US/docs/voice_ip_comm/cucmbe/rel_notes/6_1_2/cucmbe-rel_note-612_2.html#wp308676
Using Call Pickup Groups with BLF Pickup
The Busy Lamp Field (BLF) Pickup feature adds call pickup capability to BLF SpeedDial buttons. When enabled, this feature alerts a user when a BLF SpeedDial destination gets an incoming call so that the user can pick up the call. Call pickup groups control which phones a user can monitor and access. A call pickup group can now include a hunt pilot to support line group pickup.
.The busy lamp field indicates the line state at the remote device. BLF alerting is indicated by an animated icon, LED appearance, and optional tone. You can enable audible alerts at the system and device level.
An alerting call state makes the BLF Pickup button function available. When the user presses the BLF Pickup button, the phone picks up the call.
•If the monitoring device has multiple lines, the system uses the primary line as the pickup line or the next available line if the primary is not available.
•If the monitored destination is receiving multiple calls, the first call or the higher priority MLPP call gets picked up; any remaining calls continue to trigger the alerting status on the BLF Pickup button.
•If the user at a monitored destination answers the call before call pickup, the BLF Pickup button displays a busy status.
After call pickup, the BLF Pickup button status reverts to the current status for the monitored destination: idle, busy, or DND (when enabled with the "BLF Status Depicts DND" service parameter).
As admnistrator, you must modify the standard line button template to include the BLF SD option for users to invoke the BLF pickup feature. See "Configuring a Customized Phone Button Template for BLF SpeedDial Buttons" in the Presence chapter for more information.
The following phone models are equipped with BLF line buttons and support the BLF pickup feature: Cisco Unified IP Phone 7931, Cisco Unified IP Phone 7941, Cisco Unified IP Phone 7961, Cisco Unified IP Phone 7970, and Cisco Unified IP Phone 7971. The Cisco Unified IP Phone Expansion Module 7914 supports this feature when connected to one of these phone models.
Hope this helps!
Rob
kpintens Wed, 02/18/2009 - 06:07
Hi Rob
Thanks for the info but it is not working
When I press the BLF SD I get key is not active on the phone display
chrisgapske2 Thu, 02/02/2017 - 14:33
OMG Cisco is the worst phone system in the planet EVERYTHING is cobbled together and is horrible. It is worse than cisco IOS of 15 years ago.
Can't they just do something right on the call manager  where the darn system can do this on its own.
Correct Answer
Rob Huffman Wed, 02/18/2009 - 08:37
  • Hall of Fame,
    Founding Member
Hi Koenraad,
Rob
kpintens Wed, 02/18/2009 - 22:21
Thanks Rob
There are indeed no pick up groups, due to the fact that when you read the 7 info about it, it doesn't mention it. It was more tick the box and bang you can pick up the call.
I will configure a group and see what that says
Koen
Nicolas Mansour Mon, 05/11/2009 - 02:43
Anyone has a clue why would the call pick check button disappear from the BLF speed dial menu?
Nick
