02-18-2009 03:09 AM - edited 03-06-2019 04:05 AM
Hi all, is it possible to manage most new switches, 2975, 3560 etc via http? and also is it possible to graph statistics using the http etc ?
02-18-2009 03:24 AM
Yes - add the "IP HTTP Server" command.
Configure a username and password with level 15 "OR" at the http page authentication just put in the Priv Exec password with a blank username field and this will also let you in.
Older switches require older versions of Java and the 3750's are best for graphs and stats.
02-19-2009 01:37 AM
what can we configure in the GUI? can we get graphs of port stats etc for say the 2960's etc ?
02-19-2009 02:08 PM
You can configure, for example, port vlan membership, port speed, duplex speed. You also have the option to enable the macros on a switch.
Port stats on the HTTP is also possible.
If you have softwares like Spectrum or HP OpenView, for example, it can pull the port stats using SNMP.
02-18-2009 02:16 PM
You may also want to consider Cisco Network Asssitant software.
Cisco Network Assistant Data Sheet
www.cisco.com/en/US/prod/collateral/netmgtsw/ps6504/ps5931/product_data_sheet0900aecd8068820a.html
