02-18-2009 04:07 AM
Am unable to connect to VPN gateway through VPN Client.The configuration is as follows.
username manju password 0 cisco
crypto isakmp policy 1
encr 3des
authentication pre-share
crypto isakmp client configuration group vpnclient
key airtel@123
domain netsol.com
pool ippool
acl splitremote
crypto ipsec transform-set myairtel ah-md5-hmac esp-3des
crypto dynamic-map dynmap 10
set transform-set myairtel
reverse-route
crypto map clientmap client authentication list userauthen
crypto map clientmap isakmp authorization list groupauthor
crypto map clientmap client configuration address respond
crypto map clientmap 10 ipsec-isakmp dynamic dynmap
interface Loopback0
ip address 10.11.10.1 255.255.255.0
ip nat inside
ip virtual-reassembly
interface Loopback1
ip address 172.16.10.1 255.255.255.0
interface Loopback2
ip address 172.16.20.1 255.255.255.0
interface Loopback3
ip address 172.16.30.1 255.255.255.0
interface Loopback4
ip address 172.16.40.1 255.255.255.0
interface Loopback5
ip address 172.16.50.1 255.255.255.0
interface FastEthernet0/0
ip address 10.97.37.252 255.255.255.0
ip nat outside
speed auto
full-duplex
no mop enabled
interface FastEthernet0/1
no ip address
duplex auto
speed auto
interface FastEthernet0/1.1
encapsulation dot1Q 1 native
ip address 10.97.38.1 255.255.255.0
interface Serial0/0/0
description PE40-AIRTEL-NOC [10.20.30.2/29]
ip address 172.26.16.14 255.255.255.0
clock rate 2000000
interface Serial0/0/1
ip address 20.20.20.1 255.255.255.0
encapsulation frame-relay
clock rate 2000000
frame-relay map ip 20.20.20.2 100 broadcast
frame-relay lmi-type ansi
interface Serial0/1/0
interface Serial0/1/1
ip address 192.168.10.1 255.255.255.0
router eigrp 10
redistribute static
network 10.0.0.0
network 172.16.0.0
network 172.26.0.0
network 192.168.10.0
no auto-summary
ip local pool ippool 192.168.1.1 192.168.1.2
ip route 0.0.0.0 0.0.0.0 10.97.37.254
02-18-2009 01:08 PM
Can you get the debug crypto isakmp from your router when you are trying to connect?
02-18-2009 10:51 PM
02-19-2009 07:55 AM
Ok I see what you are missing, try to change the DH group of the isakmp policy to 2 instead of 1 which is what you have right now:
encr 3des
it should look like this:
encr 3des
group 2
