SNMP and the ACE Blade
Feb 18th, 2009
Hello there
This is a bit of a vague question..sorry
But, does anyone have any idea which MIBs are REALLY supported for the ACE module/blade for the 6500?
I have a customer with an Infovista NMS and is unable to pull any stats for the ACE blade - both admin and user contexts?
Has anyone had any success pulling SNMP data for the ACE blade?
The blade is running Version A2(1.0) [build 3.0(0)A2(1.0)
Thank you all.
Overall Rating: 5 (1 ratings)
Gilles Dufour Wed, 02/18/2009 - 05:01
A simple snmpwalk works for me.
[[email protected]-1 cisco]# snmpwalk -v2c -c cisco 192.168.30.121
SNMPv2-MIB::sysDescr.0 = STRING: Application Control Engine Service Module
SNMPv2-MIB::sysObjectID.0 = OID: SNMPv2-SMI::enterprises.9.1.730
SNMPv2-MIB::sysUpTime.0 = Timeticks: (1875414) 5:12:34.14
SNMPv2-MIB::sysContact.0 = STRING:
SNMPv2-MIB::sysName.0 = STRING: switch
Is your customer able to do that ?
We support partially the following MIBs
CISCO-SLB-MIB
CISCO-ENHANCED-SLB-MIB
CISCO-SLB-EXT-MIB
And also some of the standard MIBs
Gilles
olumidekomolafe Mon, 03/02/2009 - 04:12
Hey Gilles
If you are still reading this thread, I have managed to do an SNMP walk / get-next to the MIBs listed above. I must say the results I got back were quite dissapointing.
got some stuff for
1.3.6.1.4.1.9.9.161, quite a bit for SLB-EXT-MIB - but only Admin context,
Nothing on the virtual contexts.
And only a value for the ENHANCED-SLB-MIB. (cesRealServerNotifEnable)
Is this really all I can get from the ACE Blade via SNMP?
Gilles Dufour Mon, 03/02/2009 - 04:18
not sure what you are looking for.
But you can get the status of all objects like rserver, serverfarm, vserver, probes, ... which is basically all you need.
If you need a tool to configure the box, try ANM.
If you want to build your own tool or colelct information that does not exist in snmp mib, you can use the xml interface.
Gilles.
olumidekomolafe Mon, 03/02/2009 - 06:33
As you said I am interested in physical attribs for the blade itself like CPU, memory and rserver,serverfarm,virtual server for various contexts on the blade
Thks..
Gilles Dufour Mon, 03/02/2009 - 06:47
if you want context specific information, you need to configure snmp in the context itself and access the snmp info through the context ip address.
You can also get the same info from the admin context, but you need to use a special request to specify the contect name.
See the following link for more information:
http://www.cisco.com/en/US/docs/app_ntwk_services/data_center_app_services/ace_appliances/vA3_1_0/configuration/admin/guide/snmp.html#wp1082931
Gilles.
olumidekomolafe Thu, 03/05/2009 - 08:25
Many thanks for your pointers Gilles..
It turns out the main issue was lack of snmp configuration in the user specified context. I have used the other method of contatenating the context name to the community string and I can see now see a lot more information but its just not what I want to see - nothing useful for realservers, some stats for serverfarms and virtual servers - the index of the OIDs for things am seeing is way past the index descriptions in the MIB and SNMP object navigator.. I am of the mind of getting the configs onto the context before pursing with TAC further...
and thank you for the link.
