PIX vs ASA
gandhi.ganesh
What is the difference b/w PIX & ASA?
12 Replies 12
Andrew,
This is fine, but i want main feature difference b/w these two
Hardware, Functionality, thru-put, cost, encryption - which?
Think has if ur attending an interview.
the interviewer will ask u what is diff b/w PIX & ASA?
what will be ur answer?
I would say the same thing - what crieria do you want to compare on.
But to answer your question "what is diff b/w PIX & ASA?" the difference is the name:-
PIX = Packet Internet eXchange
ASA = Adaptive Security Appliance
HTH!!!!!
very funny,
lets take functionality & throughput
The PIX does not do:-
SSL/VPN
Advanced Inspection and Prevention Security
Content Security and Control Security
IPS
Intelligent Detection
ASA has better clear text & encryption thru-put than the PIX.
Max Thruput - vpn thruput - model
150mbps 100mbps 5505
300mbps 170mbps 5510
450mbps 225mbps 5520
650mbps 325mbps 5540
1.2Gbps 425mbps 5550
5Gbps 1Gbps 5580-20
10Gbps 1Gbps 5580-40
THX FOR UR VALUABLE TIME
np - glad to help.
what exactly does it mean when the ASA can handle up to 100mb of throughput on a vpn connection?
It means the ASA can encrypt and decrypt 100 mega bits per second.
HTH>
but on a vpn tunnel between 2 locations the tunnle will only be as fast as the slowest connection? My customer is currently running a 501 pix for their site to site and upgrade to 3mb up/down on both locations will they see a huge speed increase by upgrading to the 5505 ASA for their VPN termination?
