02-18-2009 05:02 AM - edited 07-03-2021 05:11 PM
I want to upgrade my 4404 controller to 5-2-178-0. I am on 5.2.157.0
in the controller I go to commands/upload.
File type: configuration
Configuration File Encryption: Checked
Encryption Key: I dont know what to put here
Transfer Mode: TFTP
IP Address: 172.16.19.112
File Path: C:\Controllerupdate
File Name: AIR-WLC4400-K9-5-2-178-0.aes
i open tfpt32
Current Directory: C:\Controllerupdate
IP: 172.16.19.112
I hit the upload button on the controller and it tells me File transfer failed!.
What am I doing wrong?
02-18-2009 06:29 AM
If C:\Controllerupdate is the default path,
try leaving the File Path: option blank on the controller.
I use linux tftp with /tftpboot as my default tftp dir and never use the file path option when upgrading my controllers
02-18-2009 06:41 AM
when you say default path do you mean the path that is in tftp32's "current directory" when i start it up?
If so then C:\controllerupdate is not. I changed it. It always points to my desktop when I open it.
02-18-2009 06:50 AM
Whatever you specify in tftp32 as the filepath will be the default path.
for example:
if you set the path in tftp32 to C:\temp
that is your default path. You do not need to specify anything on the controller
if you place the image file in say, C:\temp\images, but C:\temp is your default setting, then the File Path option on the controller would be
/images
02-18-2009 09:33 AM
Okay.
To upgrade the controller, do I need to go to download or upload. I tried upload and things actually started happening for me.
My tftp32 was responding to me but while it was almost done it gave me this message
% Error: Config file transfer failed - Error while writing output file
I was using file type configuration. Should I be using code or something else?
02-18-2009 09:59 AM
transfer download datatype code
transfer download serverip
transfer download filename
transfer download start
should be all you need
02-18-2009 02:58 PM
Download and use CODE.
02-19-2009 04:24 AM
Ok it worked with the download code.
Thanks all
02-19-2009 05:23 AM
I updated one controller with one more to go. Just in case i mess something up, is there a way to save a config on my 2nd controller in case I have to go back?
02-19-2009 05:19 PM
You want to save the config? Sure you can.
Go to Commands -> Upload File -> File Type: Configuration -> Filename: Filename you want
Hope this helps for you.
PS: Please rate if post is helpful. Thanks. :)
