Ciscoworks visibroker Smart agent
Feb 18th, 2009
Can someone tell, what is the role of CiscoWorks visibroker smart agent in LMS.
I cannot see it in my server while checking services.
Does it affects if it not present?
Is it in the advance versions of LMS?
Overall Rating: 5 (1 ratings)
miheg Wed, 02/18/2009 - 05:30
  • Gold, 750 points or more
You better check the status of the processes within the ciscoworks GUI.
I don't recall for older versions of LMS but you should have about 65 proccess in running mode, 2 in shutdown and 0 in failed to start.
Id that is the case you should not worry
Cheers,
Michel
akemp@powertel.com Wed, 02/18/2009 - 05:55
  • Silver, 250 points or more
If my memory serves me correctly visibroker was done away with the 2.6 upgrade.
Joe Clarke Wed, 02/18/2009 - 10:06
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
VisiBroker was done away with in LMS 3.1.
Joe Clarke Wed, 02/18/2009 - 10:07
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
This is the CORBA broker. It is vital for process like jrm and ANIServer. It must be present. Check the output of pdshow for the RmeOrb and RmeGatekeeper daemons.
Martin Ermel Thu, 02/19/2009 - 00:30
  • Blue, 1500 points or more
I was wondering last week about where /NMSROOT/lib/vbroker directory is gone... Is it no more necessary for CORBA to have a specific interface configured for communication in gatekeeper.cfg or have they changed the framework for the event bus?
Joe Clarke Thu, 02/19/2009 - 14:07
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
We replaced Visibroker with JacORB in LMS 3.1. It can detect multi-home configurations dynamically.
