fdarwazeh Thu, 02/19/2009 - 20:07
1) login to the ASA and type
#session 1
2) on the IPS prompt type
#setup
3) then fill up the setting based on the questions, and configure the management IP address.
4) configur your PC or LAPTOP with IP address from the same subnets and connect through the GUI interface and then use the Wizard for configuring the sensor.
enjoy
rhermes Fri, 02/20/2009 - 09:37
  • Gold, 750 points or more
step 3 1/2 - connect a cable to the management port of the AIP-SSM, this is how you'll be accessing the unit via ssh and https.
