PIX peer redunancy
Feb 18th, 2009
Hi ,
We are using pix 515E with IOS version 6.3 3 with the serial failover
From the PIX we have established a VPN to our head office which as the two ISP connected
in this condition we already have VPN but in case of the primary ISP down we have failover in the VPN
In router we will option that for the same crypto map we can have two set peer address
so is there any way to do the same in the PIX since i have studied some Dead peer deduction
can anyone help me in this
robertson.michael Wed, 02/18/2009 - 12:51
  • Silver, 250 points or more
Hi Vinoth,
I'm not sure exactly what you are trying to do, but below are some links which hopefully will help. Also, I do not believe Dead Peer Detection was added until 7.x, so this would not be available to you in 6.3(3).
Site-to-Site VPN Configuration Examples:
http://www.cisco.com/en/US/docs/security/pix/pix63/configuration/guide/sit2site.html
'crypto map' Command Reference (where the peer is set):
http://www.cisco.com/en/US/docs/security/pix/pix63/command/reference/c.html#wp1034654
If these documents do not answer your questions, please try to clarify and we will be glad to help.
-Mike
