ACS and SSID
Feb 18th, 2009
We have the following requirement.
SSID 1
Authenticates against cisco radius which uses external active directory to authenticate against
SSID 2
Authenticates guests against cisco radius which uses proxies authentication request to other institutions radius servers
These cisco radius servers are separate at the moment. We would like to combine them into one.
How do you ensure that users on one SSID are authenticated only against the appropriate authentication directory via the one radius.
Miron
mironduplessis Wed, 02/18/2009 - 07:52
JG,
Thanks for the pointers mate.
Within that document it doesnt specify SSID anywhere really. Is that something that is identified in a radius attribute that can be used for the decision making?
Miron
Jagdeep Gambhir Thu, 02/19/2009 - 09:49
WLC use DNIS-The called-station-ID (attribute 30) to send SSID name.
So we need to choose attribute 30 from that list.
~JG
Do rate helpful posts
