Vista 32bit and Cisco VPN client
Just astarting the migration to a new Vista 32bit laptop.
Downloaded the Cisco VPN client 5.0.05 which is in "Beta" and tried to install it.
It gave a bunch of errors. Before opening a TAC case, was wondering if anyone had any good news.
And I have admin rights on the pc.
Thanks.
6 Replies 6
Ivan Martinon
Level 7
Level 7
More than good news is a question, was this workstation upgraded from windows XP or is it a clean Vista installation?
this is a clean install on a new PC. a lenovo T500 is it makes any difference. 3 Gig of Ram
OK, should not fail, do you happen to have one of the messages or the message it errors with?
Here are the two error messages at the end
VPN Client Install: Setup failed to properly install Cisco Systems Service Software
Followed by
Error Loading C:\Windows\system32\csgina.dll the specified module could not be found.
I did an uninstall and reinstall and got the same thing. When I uninstalled I also got the following error:
Failed to unregister CVPNDRV with DNE
and
Failed to uninstall DNE
Oh that's nasty.. sorry to tell you but you got to go to TAC
That I what I was afraid it was leading to. Thanks for listening.
