Windows password problem with CiscoSecure ACS Release 3.3(2) Build 2
Feb 18th, 2009
Windows password problem with ACS 3.3(2). Yesterday afternoon at my office, when I login to Winodws 2003 network, it told me my password will expire in 10 days, and asked me if I want to change it. I just clicked the cancel button. Then when I went home and try to login with VPN, I could not login in, and the error message is something due to incorrect password. I tried to login few times, and my Windows acccount finally got lock out. I think when I login through VPN, Windows network asked me to want change the password; however, Cisco ACS 3.3(2) build 2 does not how to handle that. Is this a known issue in ACS of this version, or there is something I can do to fix this problem.
Overall Rating: 4 (1 ratings)
Jagdeep Gambhir Fri, 02/20/2009 - 09:20
  • Red, 2250 points or more
I would like to inform you that RADIUS Password Expiry is supported with External
windows database using MS-CHAPv2. We cannot use RADIUS Password Expiry with local ACS
database. I've attached a link for your reference.
Link for Configuring the Cisco VPN 3000 Series Concentrators to Support the NT Password
Expiration Feature Using the RADIUS Server:
http://www.cisco.com/en/US/products/hw/vpndevc/ps2284/products_configuration_example09186a
00800946b9.shtml
Please provide more information about your network, like which db, NAS, authentication you are using,
~JG
Do rate helpful posts
