02-18-2009 07:08 AM - edited 03-18-2019 10:31 PM
We have deployed CCM 6.0.1 on MCS-7816 H3. Today we have noticed blinking orange light on the front panel. What does it mean? Hardware failure? How to diagnose this problem?
Solved! Go to Solution.
02-19-2009 09:53 PM
Considering it says DIMM FAULT, I would say YES!! Please open a TAC case if this server is under warranty so that more can be done for you. TAC can call HP and get a new DIMM ordered. Again, it would be good to look at your system logs and application logs in the event viewer as this would probably tell you there is a problem with your memory without having to open the case.
Tray
02-18-2009 08:04 AM
If it's a blinking orange light on a hard drive, it very well could be. Please be more specific. Where on the server is the light. Is the light just a light or does it have an icon on it? Also, if you look at your Event Viewer application logs or system logs, is there anything indicating that you have a hard drive failure or RAID failure? We need more info.
Thanks!
Tray
02-18-2009 09:52 AM
02-18-2009 10:06 AM
Can you send this as an mpeg? I get audio but no video on this.
Tray
02-18-2009 11:47 AM
02-18-2009 01:37 PM
That is your system health indicator. I had asked you to check your application and system logs in the event viewer but you have not so far. I bet you that there is some errors and/or warnings about what is going on. If you just search google for HP Proliant Front Panel indicator light amber you can find this.
http://www.icare.hp.com.cn/TechCenter_StaticArticle/31804/35088.pdf
Tray
02-19-2009 03:02 PM
02-19-2009 09:53 PM
Tray
