paolo bevilacqua Wed, 02/18/2009 - 07:35
  • Hall of Fame,
    Founding Member
See attached performances. Obviously the 1841 has limited expansion capabilities and no voice support at all.
dhopper82 Wed, 02/18/2009 - 07:47
Thanks, Anybody have any performance reports on the 1841?
paolo bevilacqua Wed, 02/18/2009 - 07:48
  • Hall of Fame,
    Founding Member
It's in the document above. Note there is 2801 model between 1841 and 2811 so I don't know how you are forming your selection but missing a very popular choice.
dhopper82 Wed, 02/18/2009 - 08:04
We're comparing the 2 and trying to decide if the 2800's expansion module is worth the additional cost that we would incur. The 2801 doesn't have that large slot.
paolo bevilacqua Wed, 02/18/2009 - 09:22
  • Hall of Fame,
    Founding Member
Correct, but possibly you can do things on the 2801 that aren't possible on the 1841, like voip, higher density interfaces, etc.
Joseph W. Doherty Wed, 02/18/2009 - 10:48
One issue I've found with a 2801 vs. 2811, the 2801 doesn't, I believe, support Etherchannel. Most wouldn't care, but I was surprised when I bumped into this.
paolo bevilacqua Wed, 02/18/2009 - 10:52
  • Hall of Fame,
    Founding Member
Well the thing is that 2 x FE is already a bit too much for a 2801 so I think it makes sense performance-wise. On the other hand I suppose with an switch HWIC you could do that anyway.
dhopper82 Wed, 02/18/2009 - 10:55
Yeah, it's looking like it's going to be the 2811 with it's expansion module or the 1841. The 2801 is just slightly better than the 1841 or 61 so we would probably go with those 2 options first. It's looking like the 2811 is in front at the moment.
dhopper82 Wed, 02/18/2009 - 11:42
Does anybody have any listings for mean time to failure of the 1841 and 2811??
Leo Laohoo Thu, 02/19/2009 - 14:30
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
I've posted the Meat Time Before Failure (MTBF) for the 2800 into your other post.
