7600 SUP-720 3bxl
anasubra_2
Hi All,
Trying to find a comparison between an Juniper M series router and the cisco 7600 router with sup-720 3bxl.In relation to that, would like to see a link which would provide the below details.
7600 Sup-720-3bxl(1 gb DRAM,512mb flash)
Maximum bgp instances ?
Maximum BGP peers ?
Maximum OSPF instances ?
Maximum OSPF routes ?
Maximum static routes ?
Meantime between failures(Bellcore Model) ?
If you could refer to any official cisco link,which could provide the above info would be great.
Any help is really appreciated.
Anantha Subramanian Natarajan
Hi Giuseppe,
Thank you very much for the above details and its very useful.
I am not able to find these below specifics
Maximum BGP peers ?
Is it possible to find these values for sup-720-3bxl and as well as RSP720-3c-xl.
Once again,thank you
Anantha Subramanain Natarajan
Hello Anantha,
these are performance data in detail.
max bgp instance ?
1 you can have only one process but this comes from the protocol
max bgp peers ?
500 for sure, may be 1000 if not using aggressive timers.
max OSPF instances ?
32 but there is a feature for OSPF instances in VRF that goes beyond this
max OSPF routes ?
the limits are those of the protocol:
you shouldn't go over 5000-10000 routes in a single instance
max static routes ?
I don't know
I don't know
Hope to help
Giuseppe
Hi Giuseppe,
Thank you very much . Do you know any cisco official link with the above details mentioned.
