02-18-2009 09:15 AM - edited 07-03-2021 05:11 PM
In a WLC 4402 firmware v.5.2.157 is there any way to assign users to a VLAN dynamically based on the RADIUS response received from the ACS?
Solved! Go to Solution.
02-18-2009 10:51 AM
Yes and no. you can do this for an internal 802.1x WLAN, as the client does not get an IP address until they have completed the authentication process. For this you use 64/65/81, 64 802 , 65 VLAN
If as this says for Web Authentication, the answer is no. The client has an IP address prior to being validated by the AAA server.
HTH,
Steve
02-18-2009 10:51 AM
HTH,
Steve
02-19-2009 05:20 AM
Thanks. I had gathered as much from the documentation but just wanted to make sure there wasn't an alternative method.
