Basic Route-Map Configuration
Answered Question
Feb 18th, 2009
I need assistance in creating a route-map that will filter all traffic coming from 10.8.5.0/24 and send it to the next hop (10.0.0.9). Right now, when I ping 2.2.2.2/32 it takes the blue path. I want to use route-map to force traffic orginating from 10.8.5.0/24 to take the red path. Attached is the network diagram and the configuration from a L3 switch (3550), which I'm using as a router. Thank you in advance.
Correct Answer by Giuseppe Larosa about 7 years 11 months ago
Hello David,
two notes:
I wouldn't use the log option in the ACL used in the route-map this can be a problem in production
use debug ip policy to see PBR in effects
b) I don't understand Vlan3 that is on that switch but probablyou used it for test
the config looks like fine and also the place where you have applied inbound on link with sa6 is the right one
Hope to help
Giuseppe
Correct Answer by Jon Marshall about 7 years 11 months ago
David
On your 3550 switch you have used the wrong route-map name ie. you have
interface FastEthernet0/46
description SA06 Fa0/0
no switchport
ip address 10.0.0.14 255.255.255.252
ip policy route-map pbr
speed 10
duplex full
spanning-tree portfast
but your policy map is called test ie.
route-map test permit 10
description route 10.8.5.0 to fa0/1
match ip address pbr
set ip next-hop 10.0.0.9
so under fa0/46 interface
SA01-R1(config)# int fa0/46
SA01-R1(config-if)# no ip policy route-map pbr
SA01-R1(config-if)# ip policy route-map test
Jon
Overall Rating: 5 (2 ratings)
Correct Answer
Jon Marshall Wed, 02/18/2009 - 10:02
David
no switchport
speed 10
duplex full
Jon
Correct Answer
Giuseppe Larosa Wed, 02/18/2009 - 10:05
Hello David,
two notes:
Hope to help
Giuseppe
