IOS Collect Command
Feb 18th, 2009
What version of IOS code must be running on WS-C3750G-48PS-E/WS-C3550-48-EMI in order to view the TOP TALKERS on ports? The SH TOP command in CATOS is very helpful and I am looking for a similar command but only in IOS. Most of the installed switches are at rev level 12.2(25)SEB4. Thanks in advance!
Overall Rating: 5 (1 ratings)
Yudong Wu Wed, 02/18/2009 - 10:19
  • Gold, 750 points or more
I don't think this is supported in CAT3750/3550 since "toptalkers" should be calculated on Netflow data.
JOHN APONTE Wed, 02/18/2009 - 10:42
I recall on another post that it was a 2 step process.
collect top 10 counters int all
sh top counters int report
I am just not sure what rev level of IOS code you must for the command to work.
Netflow data ? Can you explain. tnx!!
Leo Laohoo Wed, 02/18/2009 - 13:58
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
I don't think you can find this on the 3750. However, as a substitute, try using the following commands:
sh interface counters
sh controllers utilization
Does this help?
Yudong Wu Wed, 02/18/2009 - 13:58
Toptalker will need netflow feature. But 3750/3550 does not support netflow feature. That's why you don't have "toptalker" on 3750/3550
