Blocking DHCP at ASA
Feb 18th, 2009
Good Day,
I have seven subnets that previously used public IPs exclusively w/helper addresses configured on a router that I *do not* control.
We recently installed an ASA 5550 to do nothing more than perform NAT for five on the subnets, the other two retain the use of public IPs.
The DHCP server we planned to use is on a public IP subnet. The ethernet port on this box is configured for Dot1q trunking and listens on all ports for DHCP broadcasts.
The problem, or peculiarity, I'm seeing is that the DHCP requests hit the server twice--once as a simple broadcast and again after passing through the ASA, hitting the router and being directed by the helper address. (all this in spite of using the ASA as an interim DHCP server)
I could request that the helper addresses be removed, but my first thought was to simply block port 67 and 68 from passing through the ASA. I have applied the "nodhcpout" acl to both inside and outside interfaces, but the traffic still passes. I have also disabled same-security traffic with the same result.
Any insight is appreciated. Here's the config from one context:
nat/vlan540# sh run
: Saved
ASA Version 8.0(4) <context>
hostname vlan540
domain-name domain.com
enable password
passwd
names
interface GigabitEthernet0/1
nameif 54lowerout
security-level 0
ip address xxx.xxx.xxx.2 255.255.255.128
interface GigabitEthernet1/0.3
nameif 54lowerin
security-level 0
ip address 172.18.0.1 255.255.0.0
dns domain-lookup 54lowerout
dns server-group DefaultDNS
name-server xxx.xxx.xxx.x
access-list allow extended permit ip any any
access-list nodhcpout extended deny udp any any eq bootps
access-list nodhcpout extended deny udp any any eq bootpc
access-list nodhcpout extended permit ip any any
pager lines 24
logging enable
logging trap alerts
logging host 54lowerout x.x.x.x
logging message 305012 level alerts
logging message 305011 level alerts
logging message 305010 level alerts
logging message 305009 level alerts
mtu 54lowerout 1500
mtu 54lowerin 1500
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
global (54lowerout) 1 x.x.x.x netmask 255.255.255.128
nat (54lowerin) 1 172.18.0.0 255.255.0.0
access-group allow in interface 54lowerout
access-group allow out interface 54lowerout
access-group nodhcpout in interface 54lowerin
access-group nodhcpout out interface 54lowerin
route 54lowerout 0.0.0.0 0.0.0.0 x.x.x.x 1
timeout xlate 0:06:00
timeout conn 0:06:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
aaa authentication ssh console LOCAL
no snmp-server location
no snmp-server contact
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
telnet timeout 5
ssh x.x.x.0 255.255.255.128 54lowerout
ssh timeout 15
dhcpd dns x.x.x.x
dhcpd lease 1800
dhcpd address 172.18.0.10-172.18.1.9 54lowerin
dhcpd enable 54lowerin
no threat-detection statistics tcp-intercept
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect netbios
inspect rsh
inspect rtsp
inspect skinny
inspect esmtp
inspect sqlnet
inspect sunrpc
inspect tftp
inspect sip
inspect xdmcp
service-policy global_policy global
Cryptochecksum:194296e16f28f367fd9988f2289b15bd
: end
nat/vlan540#
