Chris Deren Wed, 02/18/2009 - 18:00
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
Instead of building a route filter for this it would be very simple to add matching route pattern: 9.1XXX5551212
HTH,
Chris
gmoeller1 Thu, 02/19/2009 - 15:18
If you were to use a filter, couldn't you just set: Area-Code "Exists", Long-Distance-Code "Exists", Office Code == "555", and Subscriber == "1212"? I haven't had the opportunity to test, but believe that should work.
