WS-X6704-10GE -10GBASE-SR
Answered Question
Feb 18th, 2009
Hi All,
We have a 10G DWDM circuit terminated on 7600-sup720-3bxl (WS-X6704-10GE,10GBASE-SR) interface and we get below optical receive power measured on the router
sh interfaces tenGigabitEthernet 9/2 transceiver (o/p modified for simplicity)
Optical
Rx Power
Port (dBm)
Te9/2 -2.6
We are trying to understand,what would be the cisco recommended optical rx power levels. Any help on this would be really appreciated.
Anantha Subramanian Natarajan
Correct Answer by Leo Laohoo about 7 years 11 months ago
You want the Data Sheet for Cisco 10GBASE XENPAK Modules? Here's the link:
www.cisco.com/en/US/prod/collateral/modules/ps2797/ps5138/product_data_sheet09186a008007cd00_ps5455_Products_Data_Sheet.html
Does this help?
Correct Answer by Tom Randstrom about 7 years 11 months ago
Per the following data sheet, the XENPAK-10GB-SR module has a receiver range of -1.0 (max) to -9.9 (min). Your -2.6 dBm input would fall within the range.
What transmit equipment (specs) is connected to this receiver port? Might you have a optical power meter handy to verify the router's reading (I can dream)?
<http://www.cisco.com/en/US/prod/collateral/modules/ps2797/ps5138/product_data_sheet09186a008007cd00_ps5455_Products_Data_Sheet.html>
Overall Rating: 4.3 (3 ratings)
anasubra_2 Wed, 02/18/2009 - 14:02
Hi leolaohoo,
Thanks for the reply. We using a non-colured XENPAK and no wavelength mapping upto the router. Do you have a link where there is a data sheet for normal xenpak terminating 10gig interface on 10Gbase-SR interface type.
Thanks once again
anasubra_2 Wed, 02/18/2009 - 16:46
Hi Leolaohoo,
Yes and thank you very much
Correct Answer
Tom Randstrom Wed, 02/18/2009 - 13:58
