MPLS with Dynamic NAT
cjake7777
I am trying Dynamic NAT to work on 7206. I am using this on my VRF interface. I was able to get static to work, but my MPLS cloud has 30 enpoints and I want all of them to share the same public IP. I will attach my config.
10.20.20.21 is the MPLS site
8.86.131.201 needs to be the NATed IP.
Thanks!
Laurent Aubert
I think you should add the overload keywork in your ip nat inside statement to be sure you activate PAT.
Also be sure the remote PE connected to the destination has a route to join 8.86.131.201 for the return path.
Laurent.
I opened up a case and found the answer.
Restrictions for Integrating NAT with MPLS VPNs
Inside VPN to VPN with NAT is not supported.
http://www.cisco.com/en/US/docs/ios/ipaddr/configuration/guide/iadnat_mpls_vpns_ps6350_TSD_Products_Configuration_Guide_Chapter.html
