OID for Port detection
Feb 18th, 2009
We would like to delineate
between 10/100/1000 copper ports, GigE over fiber ports, 10/100 copper
ports, 10G ports and Aysnc ports.
What OIDs can I use to make this determination? (port type (i.e., copper or fiber))
Overall Rating: 5 (1 ratings)
Joe Clarke Wed, 02/18/2009 - 13:44
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
The entPhysicalVendorType from the ENTITY-MIB is the best object to use. This will return an OID for each object in the device (including ports). You can then look in the CISCO-ENTITY-VENDORTYPE-OID-MIB to get a description of those objects. For example, a copper 10/100/1000 port will be cevPortBaseTEther, a 100 BaseT port will be cevPortNIC100, and a GBIC gigabit port will be cevPortGigBaseSX.
