Trace route not working through ASA
Feb 18th, 2009
I have a Cisco ASA 5520 with a few VLAN's (DMZ's).
Under every Interface I have added the ICMP any any rule and tracerts work fine from the VLAN's (which are on a 3750 trunked of the ASA) to the inside interface and visa versa.
The only tracerts I can't get to work are from the outside's remote VPN access using the client VPN to inside.
I have setup remote access to the ASA and have added the ICMP any any rule on the outside interface but the traces just won't show up if I trace to a device on the inside from my XP laptop.
What do I need to do?
Thanks for you help
