ATA 186 not registerd in CME 7.0.1
I have the following config main part is shown
tftp-server flash:ATA030203SCCP051201A.zup
ip dhcp pool DATA
network 172.16.0.0 255.255.255.0
default-router 172.16.0.1
dns-server 200.66.96.4 200.66.96.3
ip dhcp pool TELEFONOS
network 192.168.0.0 255.255.255.0
default-router 192.168.0.1
option 150 ip 192.168.0.1
interface GigabitEthernet0/0
no ip address
duplex auto
speed auto
media-type rj45
interface GigabitEthernet0/0.1
encapsulation dot1Q 1 native
ip address 172.16.0.1 255.255.255.0
ip nat inside
ip virtual-reassembly
interface GigabitEthernet0/0.200
encapsulation dot1Q 200
ip address 192.168.0.1 255.255.255.0
h323-gateway voip bind srcaddr 192.168.0.1
interface GigabitEthernet0/1
ip address X.X.1.18 255.255.255.248
ip nat outside
duplex auto
speed auto
media-type rj45
crypto map INTER1
telephony-service
em logout 0:0 0:0 0:0
max-ephones 5
max-dn 10
ip source-address 192.168.0.1 port 2000
calling-number initiator
timeouts interdigit 4
timeouts ringing 90
cnf-file location flash:
load ata ATA030203SCCP051201A.zup
time-zone 9
time-format 24
date-format dd-mm-yy
max-conferences 8 gain -6
call-forward pattern 9.T
call-forward system redirecting-expanded
web admin customer name Cisco password Cisco
dn-webedit
time-webedit
transfer-system full-consult dss
secondary-dialtone 9
after-hours block pattern 1 900
after-hours block pattern 2 901
after-hours block pattern 3 904
after-hours day Sun 19:00 07:59
after-hours day Mon 19:00 07:59
after-hours day Tue 19:00 07:59
after-hours day Wed 19:00 07:59
after-hours day Thu 19:00 07:59
after-hours day Fri 19:00 07:59
after-hours day Sat 19:00 07:59
directory last-name-first
create cnf-files version-stamp 7960 Feb 18 2009 16:41:48
ephone-dn 2 dual-line
number 9997
label 9997
name 9997
ephone 2
device-security-mode none
mac-address 0022.9005.BB8E
max-calls-per-button 1
type ata
button 1:2
inthe flash is load the file
37 279194 Nov 27 2008 23:21:58 ATA030203SCCP051201A.zup
what could be reason the ATA can not be registered??
regards
f.giordano
Unplug the ATA from the network. Then activate these debugs:
debug ephone register
debug ip dhcp server event
debug tftp events
Then reconnect the ATA to the network
Thx
Fabian
