Autonomous to LWAPP - supported models !!!
Answered Question
Feb 18th, 2009
Hi Netpros,
I have a bunch of APs I need to find out whether they can be upgraded to LWAPP. Please see the 'show ver'. Note: I know I need to upgrade the IOS to version 12.3(7)JA or later first .. but I would like to know whether the model will actually be supported. Your help is much appreciated.
I have read the attched document but I am still having doubts
Output of show ver:
ap#sh ver
IOS (tm) C1200 Software (C1200-K9W7-M), Version 12.3(2)JA2, RELEASE SOFTWARE (fc1)
Technical Support:
Copyright (c) 1986-2005 by cisco Systems, Inc.
Compiled Tue 01-Feb-05 18:09 by pwade
Image text-base: 0x00003000, data-base: 0x0064B748
ROM: Bootstrap program is C1200 boot loader
BOOTLDR: C1200 Boot Loader (C1200-BOOT-M) Version 12.2(8)JA, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
ap uptime is 4 weeks, 4 days, 21 hours, 56 minutes
System restarted at 13:02:15 AEDT Sat Jan 17 2009
System image file is "flash:/c1200-k9w7-mx.123-2.JA2/c1200-k9w7-mx.123-2.JA2"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
cisco AIR-AP1231G-A-K9 (PowerPC405GP) processor (revision B0) with 14326K/2048K bytes of memory.
Processor board ID FOC09050BV2
PowerPC405GP CPU at 196Mhz, revision number 0x0145
Last reset from power-on
Bridging software.
1 FastEthernet/IEEE 802.3 interface(s)
1 802.11 Radio(s)
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 00:13:60:19:01:6E
Part Number : 73-8704-08
PCA Assembly Number : 800-23211-09
PCA Revision Number : A0
PCB Serial Number : FOC09050BV2
Top Assembly Part Number : 800-23304-08
Top Assembly Serial Number : FHK0907J0VR
Top Revision Number : A0
Product/Model Number : AIR-AP1231G-A-K9
Configuration register is 0xF
Correct Answer by Leo Laohoo about 7 years 8 months ago
Overall Rating: 5 (6 ratings)
Stephen Rodriguez Wed, 02/18/2009 - 16:19
the lowdown here, is the AP needs to have a MP21G, RM21A or RM22A. If you have the older 1200 or 1100 model, you may need to upgrade the chip. Same for the A radio, if you have the older RM20A, it will not join.
dennischolmes Wed, 02/18/2009 - 17:18
Basically the radio must support AES encryption to allow the LWAPP control tunnel to be established. You can update several older models to function with LWAPP.
Fernando_Meza Thu, 02/19/2009 - 03:15
Hi Steve ..
Thanks for that ..
" AP needs to have a MP21G, RM21A or RM22A. If you have the older 1200 or 1100 model, you may need to upgrade the chip. Same for the A radio, if you have the older RM20A"
ap#show controller dot11Radio 0
interface Dot11Radio0
Radio AIR-MP31G, Address 0013.605a.b750, BBlock version 0.00, Software version 5 .60.13
Serial number: FOC0905D2VS
Will MP31G work ..?
rob.huffman Thu, 02/19/2009 - 05:29
Hi Fernando,
Just to add a note to the great tips from Steve, Dennis and Leo (3 of my faves here:) +5 points each guys for your excellent support!
You will be good to go with the radio you have installed in the 1231***;
Migration from autonomous access point mode to lightweight mode is possible on these Cisco Aironet access point platforms:
•All 1121 access points
•All 1130AG access points
•All 1240AG access points
•All 1250 series access points
•For all IOS-based 1200 series modular access point (1200/1220 Cisco IOS Software Upgrade, 1210 and 1230 AP) platforms, it depends on the radio:
***-if 802.11G, MP21G and MP31G are supported
-if 802.11A, RM21A and RM22A are supported
The 1200 series access points can be upgraded with any combination of supported radios: G only, A only, or both G and A.
We upgraded many of these same 1231's without issue when we migrated to the LWAPP Platform.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
