uRPF question
Feb 18th, 2009
How does unicast reverse path forwarding work when there is a default route in the FIB?
uRPF does a reverse check to make sure that the return sourced traffic can make it back through that same interface otherwise its dropped. Now what happens if its a spoofed source IP and uRPF checks the FIB and there is a default route? It still forwards it as usual, or am I confused?
Overall Rating: 5 (1 ratings)
Harold Ritter Wed, 02/18/2009 - 16:38
Sparky,
The default route is not considered unless you configure the allow-default keyword as follow:
ip verify unicast source reachable-via any allow-default
