VPN client issues -IKE errors
Feb 19th, 2009
I have an two ASA5510 with a Lan2Lan VPN tunnel between them. I recently configured one of the firewall to allow remote clients to also connect using the Cisco VPN client and i am now getting the following error.
3 Feb 19 2009 07:41:57 713042 IKE Initiator unable to find policy: Intf INSIDE, Src:, Dst:
does anyone know what might be causing this. both the lan2lan and the vpn client vpns are working.
Ivan Martinon Thu, 02/19/2009 - 08:11
Can you post the config here? I would like to check if it is healthy, this messages come when the traffic on the asa is not finding a matching crypto map.
