802.3ad
Feb 19th, 2009
can i configure 802.3ad for 2 gig ports on cisco 2851 router.Cisco 2851 router connected to 2 different L2 switch with each gig port and each L2 switch is connected to firwall on vertical link.i want my both firewalls and router in single subnet...
Giuseppe Larosa Thu, 02/19/2009 - 05:53
  • Hall of Fame,
    Founding Member
Hello Sameer,
I agree with Karem.
an etherchannel makes sense when going to the same device not to two different switches.
If you use IRB one link will be active and used and the second will be ready to be used.
the router will use IEE STP to manage redundancy together with the switches
Hope to help
Giuseppe
sameermunj Thu, 02/19/2009 - 20:15
So looking at the ppt i had attahced in my 1st thread,will the config will look like this
Router# configure terminal
Router(config)# bridge 10 protocol ieee
Router(config)# int Gig 0/0
Router(config-if)# bridge-group 10
Router(config-if)# cut-through
Router(config-if)# no shutdown
Router(config-if)# exit
Router(config)# int Gig 0/1
Router(config)# bridge irb
Router(config)# interface bvi 10
Router(config-if)# ip address 192.168.1.4 255.255.255.248
Router(config)#
Router(config)# bridge 10 route ip
Router(config)# exit
Router#
Both Firewall will have default route towards 192.168.1.4 and router will point static route for internal networks towards 192.168.1.3 (VRRP IP of firewall)
If Any other option in this case apart from IRB which is purely routing based please let me know
Giuseppe Larosa Thu, 02/19/2009 - 23:42
  • Hall of Fame,
    Founding Member
Hello Sameer,
the configuration is correct.
Note:
IRB : integrated routing and bridging is not a purely routing solution
the command bridge 10 protocol ieee starts an STP instance that follows 802.1D.
These BPDUs are exchanged with the two switches and a loop free path is built using 802.1D
Hope to help
Giuseppe
