Pb with config deploy : RME4.1.1
Feb 19th, 2009
HI,
I have now LMS3.0.1 with RME 4.1.1.
If i try to do a config-deploy on a device (a switch wich is successfully added in RME), it says "successfully" after a while, but in fact it does'nt deploy the config.
Also the buffer-log in the switch does'nt say that the lms connect to the switch.
I have the same pb with netconfig.
Also, software upload from device to RME repository stay all the time in running-state...
HAve you an idea ?
Michel.
mmisonne Thu, 02/19/2009 - 04:57
Apparently, after a server restart, it works now.. Strange !
