49 e1 link termination on cisco router Pls suggest suitable router
Feb 19th, 2009
Hi,gurus
Thanks in advance
Please suggest me any cisco router platform which support 49 E1 links.is 7206 router support 49 e1 links ?
thanks
sandeep
paolo bevilacqua Thu, 02/19/2009 - 05:22
  • Hall of Fame,
    Founding Member
Can you ask your telco if they can give you channelized E3 service, where you have 16 E1 on a single interface ?
That will allow you to use, for example a 7200/NPE-G1 with two PA-MC-E3.
san_dec21 Thu, 02/19/2009 - 23:15
hi,all
thanks for reply
but i want to ask is it possible to connect 49 e1 links to 7206 vxr router as we can use 8 port e1 module.and in 7206 vxr router we can use i/o slot as a 7 th slot? please correct me if i m wrong.
paolo bevilacqua Fri, 02/20/2009 - 02:10
  • Hall of Fame,
    Founding Member
No, you cannot.
My suggestion above is what is usually done for high density E1 termination: channelized E3, because it is more economical and simpler. Ask your telco about it.
