Detector module loadbalancing method ?
Feb 19th, 2009
We have a three detector module is seated in c6509 chassis.
we must detect 8 giga interface using only three detector module.
In document, there are two method of detector module capture traffic. first is monitor session and vacl,
in monitor session, we can't use due to limited local session number, so we must use VACL to loadbalancing detector module
we configured the detector module like below:
ip access-list extended myacl
permit ip any any
vlan access-map vacl 10
match ip access myacl
action forward capture
vlan filter vacl vlan-filter 10,20,30,40,50,60,70,80,
anomaly-detector-module 3 capture
anomaly-detecotr-module 3 capture allowed-vlan 10,20,30,40,50,60,70,80
we started the traffic and monitored the traffic state in c6509 msfc. however the traffic is injected to detector module like all same traffic, it's not load-balancing, it just span traffic to other detector module,
the requirement our want is to loadbalancing detector module like ECMP, just packet-by-packet on each detector module.
It is possible? if possible How could I configure on MSFC to loadbalance traffic?
I appreicate if you give to me answer as soon as possible.
thank you.
