Recently Added Device not visible in DCR but visible in RME
Feb 19th, 2009
I added a 3560G-48TS Switch to the DCR with the following:
- Device Type: Unkown Device Type
- Device Name
- Host Name
- IP Address
- User Name / PW
- SNMPv1 Community String
Unfortunately the Device isn't visible in DCR, but is in RME where a configuration was already collected.
After I try to readd this Device with the correct Device Type i get a message that this Device is already present.
Some Informations:
- Recently upgraded from LMS 2.6 to 3.1
- Previous added Device is displayed in a correct manner
- No im NOT using ACS-Mode
I'd be gladful for any help you can provide.
Joe Clarke Thu, 02/19/2009 - 14:30
How does the device show up in RME? Is it appearing in the device selector?
schlingloff Thu, 02/19/2009 - 22:54
Ok i hope i interpreted "Device Selector" in the correct way as shown in the screenshot.
As shown there i've added 2 Devices.
The "...TestSwitch"-Device is visible in DCR and RME, but the new Device ist only visible in RME.
The Test-Device was added before the Upgrade to 3.1. and is still fully operational inside the whole LMS.
Joe Clarke Thu, 02/19/2009 - 23:16
This is certainly strange. This perhaps points to missing data in the DCR tables in the cmf database. Are you able to see the device in dcrcli:
dcrcli -u admin
dcrcli> lsids all
schlingloff Thu, 02/19/2009 - 23:37
Indeed.
I issiued the commands in cmd.
All the Defices where listed.
dcrcli> lsids all
Total number of devices in DCR:2
List of devices:....
ID = 1 (...TestSwitch)
ID = 2 (BER-BE-SWT03)
(Remark: The dots where added manually by myself, since that Information may be used to identify a customer)
I've also issued the "detail" command.
dcrcli> detail id=2
Display Name = BER-BE-SWT03, Device ID = 2
This is a Standard device.
MDF Type : Cisco Catalyst 3560G-48TS Switch
Sys Object ID: 1.3.6.1.4.1.9.1.617
IP Address: 10.3.32.30
Host name: BER-BE-SWT03
Primary Username:
Primary Password:
Primary Enable Password:
SNMP V2 RO Community String:
If i'm connecting manually to the Device with Telnet i'm not forced to provide a enable-pw. I've added the same password for standard login in the enable-field.
Still RME was able to receive the config.
schlingloff Fri, 02/20/2009 - 05:39
Ok NOW i'm really confused!!
After 1 1/2 day's of headache i did a second restart.
Well, i dont know how to describe my astonishment as i actually saw the Device in DCR...
Like i said, i'm pretty confused right now. I just don't understand it. Maybe someone can give me a hint what was the cause.
Joe Clarke Fri, 02/20/2009 - 08:25
I can't answer that. As I said, not seeing a device in DCR when the you do in other applications is strange, and not something I typically see when the server is not integrated with ACS. I suppose if it's showing up now, it is possible there was a problem with CMFOGSServer previously. It must have bee running or RME would not have shown the devices. However, it may have been in a bad state.
