Making call restriction
Feb 19th, 2009
How can we make call restrictions? In the morning they should login with their user password and when they go away they should log out and noone can use their phone. Is it possible?
Jaime Valencia Thu, 02/19/2009 - 07:08
  • Cisco Employee,
  • Hall of Fame,
    2011
yes, use EM for that. it's perfect for what you want
java
if this helps, please rate
Jonathan Schulenberg Thu, 02/19/2009 - 08:05
  • Cisco Designated VIP,
    2017 IP Telephony
I'm not sure why you wouldn't use EM.. that's what it is designed for.
Anyways, other ideas:
1) Use FAC to require authorization codes for all off-net calls.
2) Look at third-party applications that provide a "phone lock" concept. Radianta's Beacon Office has this. I've also heard of (but not tried) a product from rsconnect.net called Auto Logon Module that claims to automate the EM login/logout based on the computer attached to the PC port logging on/off.
blackswans Thu, 02/19/2009 - 08:15
what I want to know is will it ask FAC always when making calls, or is there a time for it for a period of idle time ?
Jaime Valencia Thu, 02/19/2009 - 08:22
  • Cisco Employee,
  • Hall of Fame,
    2011
FAC/CMC is for every single call that goes thru a FAC/CMC enabled pattern
java
blackswans Thu, 02/19/2009 - 08:35
so whenever a call is made every user should enter the password. am I right ?
