Cisco 2960 tftp problem
Answered Question
Feb 19th, 2009
We have several Cisco 2960 switches and we have a problem after upgrading IOS.
We had : c2960-lanbasek9-mz.122-46.SE
No problem at all transfering IOS files with tftp
Now : c2960-lanbasek9-mz.122-46.SE
With this IOS, every transfer crash. Only a few bytes are transfering then everything stop. On the TFTP server we see the connection disrapering (so the switch stop downloading).
If I restart the switch in the original IOS, everything works.
Other question, can you tell me what's the purpose of the file named "multiple-fs" in the flash.
Thank you
Correct Answer by Tshi M about 7 years 8 months ago
is the same tftp server used in the lab as in the prod environment?
I would try to use a different tftp server (i.e. like your workstation) just to rule out the server.
Overall Rating: 5 (1 ratings)
Tshi M Thu, 02/19/2009 - 07:09
Hi Jean,
Both of the posted IOS are the same. Also by every transfer crash, do you mean the switch actually crashes or the transfer times out?
jphilippe.halle Thu, 02/19/2009 - 07:17
Sorry my mistake
Original IOS :c2960-lanbase-mz.122-35.SE5
The transfer just stop and nothing happens (I waited several minutes without seeing a time out).
Tshi M Thu, 02/19/2009 - 07:21
have you checked to see if you have enough space to uplaod a new flash?
dir flash:
I ran into a similar problem last week with one of my 3560.
I also had to increase the line vty exec-timeout but that might not be your case.
jphilippe.halle Thu, 02/19/2009 - 07:40
hi again,
I checked and I have enough space (more than the double).
To add details, we upgaded the IOS because we needed crypto features.
I don't understand. I took a another 2960 spare switch and put the same IOS' and I don't have the problem...
Tshi M Thu, 02/19/2009 - 07:44
Interesting fact. I'd open a TAC case if I were you. The problem seems to be isolated to that specific switch.
jphilippe.halle Thu, 02/19/2009 - 08:39
I think I have found the problem. The server running the tftp server is a windows with NIC Teaming and I think it's the problem. I removed the teaming and now the download from the switch works almost (now instead of crashing right at the begining it's crashing at ramdom % and I see CRC errors on the NIC of the server).
I'll continue investigating
Tshi M Thu, 02/19/2009 - 08:40
I will check the settings on the switchport where the server is connected. You might have a duplex mismatch.
jphilippe.halle Thu, 02/19/2009 - 09:10
Seems to be ok for speed/duplex...
If I tranfer the IOS via tftp (UDP) it's always crashing during the download. But for some reason it works perfectly over HTTP (TCP).
Am I correct to assume that we have bad packets on the network and it works over HTTP because TCP retransfer failed packets ?
Tshi M Thu, 02/19/2009 - 09:12
I am just confused cause it works on the spare switch.
jphilippe.halle Thu, 02/19/2009 - 09:20
the spare switch wasn't on the same network. It was in our lab
and it didn't work on all the switches in the same network
Tshi M Thu, 02/19/2009 - 09:25
Can you upload from the switches to the tftp server without problem?
I would also span the server port just to see what is happening when you do your transfer.
jphilippe.halle Thu, 02/19/2009 - 09:33
yes, all tranfer from switches to the tftp server works.
Only problem is from tftp to switches.
And only with the new IOS...
Correct Answer
Tshi M Thu, 02/19/2009 - 10:46
jphilippe.halle Fri, 02/20/2009 - 06:14
no it wasn't the same tftp server.
I pretty sure the problem is the computer we are using as tftp server.
I will test that later
Thanks for your help
