[UDP fast age support for ACE Module]
Feb 19th, 2009
I'm testing 2 ACE modules running A3.0.0 for DNS load balancing (UDP). We're testing this by using a DNS query generator that (always) seems to use the same UDP source port when originating these queries. At the moment, the ACE module is hardly doing any load-balancing.
It looks to me like, that because of this, the ACE believes it's the same session (connection) and doesn't really load-balance, so I started looking for a solution and found the fast-age udp feature. But, it seems this is not supported on my ACE modules. Can any one offer another solution and/or look at my config and see if there is another way to achieve load balancing in a testing environment when using a tool like the one I described?
(I put it that way because i believe in real life since queries come from different IP addresses and randomized udp ports, the ACE module will be just fine).
Thanks in advance!
c.
Overall Rating: 5 (1 ratings)
ciscocsoc Thu, 02/19/2009 - 08:40
  • Silver, 250 points or more
UDP fast-age is a Version 2 feature. Try upgrading. Version 1.6.3 is quite old now and there is lots of good stuff in Version 2.
Cathy
Carlos A. Silva Thu, 02/19/2009 - 08:45
Hi, Cathy:
So, version 3.0.0 is lower than 2.1.0?
system: Version 3.0(0)A1(6.3a) [build 3.0(0)A1(6.3a)
that means that the actual version number is taken from the last part: A1(6.3.a)?
Thanks in advance!
c.
ciscocsoc Thu, 02/19/2009 - 08:51
Hi Carlos,
Correct. The 3.0(0) is really misleading. You need to start with the "A" - so you really have 1.6.3a installed.
The "show version" for V2 is slightly better -
system: Version A2(1.2) [build 3.0(0)A2(1.2)
Cathy
