02-19-2009 09:28 AM - edited 03-06-2019 04:07 AM
All,
With the current config on a switchport:
interface FastEthernet0/1
switchport mode access
switchport voice vlan 10
no ip address
no mdix auto
spanning-tree portfast
I need to change this to a trunked port because I'll be adding more vlans to this switch. If I do, will it screw anything up with the voice side? They run Cisco IP phones, but a vendor set them up and I know nothing about them.
John
02-19-2009 09:37 AM
should not.
The packet from Cisco IP phone is dot1q tagged. Therefore, as long as you use dot1q as encapsulation on the trunk, it should work.
By the way, I did not see QoS is eabled under the interface.
02-19-2009 09:40 AM
No, that's the complete config for the switchport. When I'm done with it, it will be like
switchport mode trunk
switchport trunk allowed vlan 1,150,151
no ip address
no mdix auto
I'm assuming that the "switchport mode access" is for data only, and the switchport voice is only for voice.
John
02-19-2009 09:41 AM
You need add vlan 10 in allowed vlan.
02-19-2009 09:43 AM
Okay, thanks!
02-19-2009 10:28 AM
kwu2 is correct that you will need to add it to the trunk allowed.
However, you wont need the switchport voice vlan 10 on the interface. The switchport voice command is to inform phones that are plugged directly into the port to use that VLAN instead of the default access VLAN. Because this is a trunk, you won't be hooking up a phone to the interface=)
02-19-2009 10:30 AM
I also forgot to mention that I believe you are going to need to remove the spanning-tree portfast because that is a switchport access command and not a trunk command.
Here is exactly how we have our trunked ports configured for our VOIP environment excluding QoS:
interface GigabitEthernet0/1
switchport trunk native vlan 901
switchport trunk allowed vlan 401,501,901
end
Our 401 VLAN is standard data, our 501 VLAN is standard voice, and our 901 VLAN management VLAN
Here is the example of our access interface excluding QoS:
switchport access vlan 401
switchport voice vlan 501
end
02-19-2009 10:31 AM
Well, I'm a little concerned because I went ahead and configured the port for the access point to make sure I wouldn't lose connection. I started a continuous ping to the ap, changed the port to trunk, allowed vlan 1,150 on the trunk, and I lost a few packets (about 6). I'm HOPING that this won't bring the phones down that are connected into that switch when I move the port over to a trunked port. =)
Thanks!
John
02-19-2009 12:21 PM
You need to setup the trunk to allow all VLAN's that you use on the switch. So, if your Fa0/1 is going to be your trunk port and you are using VLAN's 1, 10, 150 and 151 than your config should look like this:
switchport trunk allowed vlan 1,10,150,151
no ip address
no mdix auto
Now you mention something about an AP? How is that fitting in with this trunk that you are trying to configure?
