Supervisor Recording
Answered Question
Feb 19th, 2009
Where are the recording files stored? and in what format?
Correct Answer by adignan about 8 years 3 months ago
The format is a .raw file. Cisco provides a utility to convert these files from .raw to .wav (raw2wav).
Reference chapter 5 here:
http://www.cisco.com/en/US/docs/voice_ip_comm/cust_contact/contact_center/crs/express_7_0/troubleshooting/guide/cad66tg-cm.pdf
please rate helpful posts
Overall Rating: 5 (2 ratings)
destiny6366 Wed, 08/26/2009 - 13:17
Can you tell me if the recording file is stored on the UCCX server? If so how do I access it.
Thanks for your help
joesnyde Thu, 08/27/2009 - 08:34
  • Cisco Employee,
Yes, the file is stored on the server, default is 7 days, but can be extended through the Supervisor recorder viewer to 30 days.
Files are located in the following directory
C:\Program Files\Cisco\Desktop_Audio
destiny6366 Thu, 08/27/2009 - 09:10
Thanks, I found it. But, how to you change it from .raw file to .wav file? I appreciate any input.
Thanks again
