ansalaza Thu, 02/19/2009 - 12:53
Configuring the Router to Use the Kerberos Protocol
http://www.cisco.com/en/US/docs/ios/12_2/security/configuration/guide/scfkerb.html#wp1001137
c3750-ipbasek9-tar.122-44.SE5.tar
Catalyst 3750 IP base cryptographic image and device manager files.
This image has the Kerberos, SSH1 , Layer 2+, and basic Layer 3 routing features.
This image also runs on the Cisco EtherSwitch service modules.
c2960-lanbasek9-tar.122-44.SE5.tar
Catalyst 2960 cryptographic image file and device manager files. This image has the Kerberos and SSH features.
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750/software/release/12.2_44_se/release/notes/OL14630.html#wp841480
halogensoftware Fri, 02/20/2009 - 12:54
Did install the suggested image on the 2960 (see below), but still do not have "kerberos" option under "conf t". What am I doing wrong?
Thanks a lot,
Evgueni
Switch Ports Model SW Version SW Image
* 1 26 WS-C2960-24TT-L 12.2(44)SE5 C2960-LANBASEK9-M
Switch(config)#?
ip Global IP configuration subcommands
ixi IXI Config command
key Key management
kron Kron interval Facility
lacp LACP configuration
li-view LI View
