What is the order to choose Dial-Peer for outside call?
Feb 19th, 2009
I have 4 outside FXO lines.
And four dial-peer for oyside call.
I wonder how cisco choose free FXO line.
first-free-line?
squentially?
lowest-time-used?
Is it possible to program it lowest-time-used?
paolo bevilacqua Thu, 02/19/2009 - 10:54
  • Hall of Fame,
    Founding Member
Yes. Under voice-port, put the lines in trunk-group. Under said trunkgroup, choose an hunt scheme. Reference trunkgroup instead of port under DP.
Jaime Valencia Thu, 02/19/2009 - 11:52
  • Cisco Employee,
  • Hall of Fame,
    2011
the other option would be to use the command
dial-peer hunt
to configure which algorithm to use, info is available on cco
java
if this helps, please rate
recep.sefer Thu, 02/19/2009 - 21:22
I have been test it,
Even I set hunt-scheme as lest use,
It choses next port as a least usage-count
I wat it to be least usage-time
Asuuming port usage as an example;
port-1 5-times (20-minutes)
port-2 2-times (30-minutes)
It choses port-2
My config is;
trunk group T-TRUNK
hunt-scheme least-used
dial-peer voice 444 pots
trunkgroup T-TRUNK
destination-pattern 9
voice-port 0/1/0
trunk-group T-TRUNK
voice-port 0/1/1
trunk-group T-TRUNK
voice-port 0/1/2
trunk-group T-TRUNK
voice-port 0/1/3
trunk-group T-TRUNK
