Allowing vpn passthrough on a ASA 5510
Feb 19th, 2009
Ok, here's my situation, mind you i'm extremely new to Cisco router/firewalls. I have a internal device that generates a vpn tunnel to a remote location. However I have a ASA 5510 as my firewall. How do I configure the ASA 5510 to allow the VPN traffic through the firewall. I have opened up the UDP, ESP, GRE ports and am allowing pinging. However I am unable to establish a connection to my remote location. I am also unable to ping to any outside location. I have checked the internal and extrenal devices and they are configured appropriately. So my issue has to be with the firewall.
If I have posted this in the wrong location please let me know the appropriate spot.
seibertmedia Thu, 02/19/2009 - 12:49
i didn't tried to build an vpn through the device, my vpn's are ending at the device. Try to check the logs of the ASA, to see if anything is dropped by acls.
Ping is a bit special. I had to allow the following icmp-types on input access-list on the external Interface:
Echo-reply (this is needed for Ping-Replys)
also you should allow the following types:
