NetConfig for AAA Tacacs and new enable secret
Feb 19th, 2009
I pushed out new configs for AAA, Tacacs and a new enable secret pw.
It appears that in CW the new credentials have to be updated manually? Can anyone verify that this has to be done? Is there an automated way of doing it?
Joe Clarke Thu, 02/19/2009 - 19:04
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
If you used the built-in Netconfig templates for password, then the credentials should have been updated automatically in DCR if you selected the option to do so. See the online help for templates such as the enable password template for more details how this works.
If you have already pulled the trigger, though, you will have to go into DCR, and update the credentials manually. If you need to do this to a large number of devices, go to Common Services > Device and Credentials > Device Management. Select the devices, then click the Edit Credentials button.
