CUE and AA
robert.exner
I have CUE on AIM and CCME.
PSTN connection is PRA with DID, on telephony-service I use dialplan-pattern.
From some of the PRA numbers ( 4 ) I need to run AA on CUE. What is the best way to route calls for PSTN for appropriate numbers to AA.
Thanks for any help
Rob
paolo bevilacqua
Simply set a voip DP (if numbers are contiguous) or more than one, to send calls to CUE.
In CUE, tie the numbers, as received from telco to the AA you want, supposedly each one is different.
